주요 콘텐츠로 건너뛰기
Lens Cover Replacement
필요한 것
  1. Lens Cover Replacement, Lens Cover: 1 단계, 이미지 1/1
    • Unscrew the two small screws on the black side panel of the camera using a PH00 screwdriver. Remove the part.
  2. Lens Cover Replacement: 2 단계, 이미지 1/1
    • You will need to remove the front panel in order to access the lens. Lift the latches on the side of the front panel to remove it entirely, pulling gently in an upward motion.
  3. Lens Cover Replacement: 3 단계, 이미지 1/1
    • Locate silver lens covering.
  4. Lens Cover Replacement: 4 단계, 이미지 1/1
    • Use your PH00 screwdriver to unscrew the lens cover.
    • Remove the screw.
    • Remove the lens cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kathleen
회원 가입일: 01/30/15
225 평판
안내서 2개 작성하였습니다
댓글 한 개
I found that additional steps are needed between steps 2 and 3 to remove 5 additional screws before the front panel can be removed.
Was my Olympus 850 SW different from the one repaired in that tutorial?
I took pictures that I could insert in the tutorial, but did not find how to do it.
Michel
Michel Martin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 28
전체 시간: 1,030
