소개
Here, we will describe how to dissemble your camera in order to properly replace the lens cover.
도구
부품
지정된 부품이 없습니다.
Unscrew the two small screws on the black side panel of the camera using a PH00 screwdriver. Remove the part.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
I found that additional steps are needed between steps 2 and 3 to remove 5 additional screws before the front panel can be removed.
Was my Olympus 850 SW different from the one repaired in that tutorial?
I took pictures that I could insert in the tutorial, but did not find how to do it.
Michel
