이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unscrew the two small screws on the black side panel of the camera using a PH00 screwdriver. Remove the part.
You will need to remove the front panel in order to access the lens. Lift the latches on the side of the front panel to remove it entirely, pulling gently in an upward motion.
Use your PH00 screwdriver to unscrew the lens cover.
Remove the screw.
Remove the lens cover.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
I found that additional steps are needed between steps 2 and 3 to remove 5 additional screws before the front panel can be removed.
Was my Olympus 850 SW different from the one repaired in that tutorial?
I took pictures that I could insert in the tutorial, but did not find how to do it.
Michel
