주요 콘텐츠로 건너뛰기
Les Paul Wireless Guitar Battery Pack Replacement
필요한 것
  1. Les Paul Wireless Guitar Battery Pack Replacement, Les Paul Wireless Guitar Body Teardown: 1 단계, 이미지 1/1
    • Remove batteries
  2. Les Paul Wireless Guitar Battery Pack Replacement: 2 단계, 이미지 1/2 Les Paul Wireless Guitar Battery Pack Replacement: 2 단계, 이미지 2/2
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Battery Pack Replacement: 3 단계, 이미지 1/3 Les Paul Wireless Guitar Battery Pack Replacement: 3 단계, 이미지 2/3 Les Paul Wireless Guitar Battery Pack Replacement: 3 단계, 이미지 3/3
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: 4 단계, 이미지 1/2 Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: 4 단계, 이미지 2/2
    • Gently move the capacitor around until it breaks off
  5. Les Paul Wireless Guitar Battery Pack Replacement: 5 단계, 이미지 1/1
    • Solder on the new capacitor.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Chris
회원 가입일: 10/18/13
881 평판
안내서 6개 작성하였습니다
댓글 2개
Mine is: 2200uF 10V
Thijs van Ulden -
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 25
30일 전: 125
전체 시간: 12,591
