주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Levoit Core 300-RAC Fan Replacement
필요한 것
  1. Levoit Core 300-RAC Fan Replacement, Air Filter: 1 단계, 이미지 2개 중 1개 Levoit Core 300-RAC Fan Replacement, Air Filter: 1 단계, 이미지 2개 중 2개
    • Make sure your device is turned off and unplugged for safety.
    • Turn the Levoit Core 300-RAC over so the bottom is facing up.
  2. Levoit Core 300-RAC Fan Replacement: 2 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 2 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Turn the bottom cover counterclockwise and lift it off to remove it.
    • The cover does not "snap" on or off when turned.
  3. Levoit Core 300-RAC Fan Replacement: 3 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 3 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the filter straight up and out of the device.
  4. Levoit Core 300-RAC Fan Replacement, Fan: 4 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement, Fan: 4 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement, Fan: 4 단계, 이미지 3개 중 3개
    • Use a Phillips #2 screwdriver to remove the four screws that secure the gray lid towards the base of the device.
    • Set the screws aside in a safe place.
  5. Levoit Core 300-RAC Fan Replacement: 5 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 5 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Use a metal spudger or Jimmy to gently pry between the four white tabs and the white housing to release the outer housing.
    • Gently pulling up on the outer housing can prevent the clips from resetting.
  6. Levoit Core 300-RAC Fan Replacement: 6 단계, 이미지 2개 중 1개 Levoit Core 300-RAC Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the outer white housing and set it to the side.
    • The power cord is fed through a hole in the side of this housing, so it has to sit right next to the device.
  7. Levoit Core 300-RAC Fan Replacement: 7 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 7 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 7 단계, 이미지 3개 중 3개
    • Grab the cable channel by its base, squeeze, and pull up at the same time to remove it.
  8. Levoit Core 300-RAC Fan Replacement: 8 단계, 이미지 2개 중 1개 Levoit Core 300-RAC Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the four Phillips #2 screws securing the gray face plate.
  9. Levoit Core 300-RAC Fan Replacement: 9 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 9 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 9 단계, 이미지 3개 중 3개
    • Insert a Jimmy or spudger between the white tab and the gray faceplate body to release the faceplate.
    • Lift it out.
  10. Levoit Core 300-RAC Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Turn your device over so it is upright again.
  11. Levoit Core 300-RAC Fan Replacement: 11 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 11 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 11 단계, 이미지 3개 중 3개
    • Insert the Jimmy between the gray grille cover and the top of the device.
    • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
    • Take note of the placement of the tabs, as they are keyed and need to go back in the exact way they came out.
    • Remove the grille cover gently as it is connected by a ribbon cable.
    • Be careful not to put too much strain on the ribbon cable as it may break.
  12. Levoit Core 300-RAC Fan Replacement: 12 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 12 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 12 단계, 이미지 3개 중 3개
    • Squeeze the tab on the connector to release the bundled cable from the control board.
    • The connector should come out fairly easily, do not force it. Pulling too hard could damage the connector.
  13. Levoit Core 300-RAC Fan Replacement: 13 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 13 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 13 단계, 이미지 3개 중 3개
    • Insert a spudger or Jimmy into the four tabs to release them from holding the outer white housing to the inner black core.
    • Remove the white outer housing.
  14. Levoit Core 300-RAC Fan Replacement: 14 단계, 이미지 1개 중 1개
    • Flip your device over again so the fan is facing up.
  15. Levoit Core 300-RAC Fan Replacement: 15 단계, 이미지 2개 중 1개 Levoit Core 300-RAC Fan Replacement: 15 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove the three screws on the upper portion of the black housing.
  16. Levoit Core 300-RAC Fan Replacement: 16 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 16 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the upper portion of the black housing.
  17. Levoit Core 300-RAC Fan Replacement: 17 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 17 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 17 단계, 이미지 3개 중 3개
    • Use a 13mm socket wrench with an extension to remove the nut holding the fan in place and remove all hardware from the threaded shaft.
    • There should be a nylon-insert lock nut, a flat washer, and a split ring washer. Set these aside in a safe location.
  18. Levoit Core 300-RAC Fan Replacement: 18 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Fan Replacement: 18 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Fan Replacement: 18 단계, 이미지 3개 중 3개
    • Lift the fan up and off of the threaded shaft.
    • There is another washer underneath the fan, leave it in place for the replacement fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Stephen Carrozza
회원 가입일: 11/01/23
253 평판
안내서 1개를 작성함
UMass Dartmouth, Team 1-6, Petersen Fall 2023 UMass Dartmouth, Team 1-6, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G6
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 33
지난 30일: 208
전체 시간: 5,787
