주요 콘텐츠로 건너뛰기
Levoit Vital 100 HEPA Filter Replacement
필요한 것
  1. Levoit Vital 100 HEPA Filter Replacement, Filter: 1 단계, 이미지 1/2 Levoit Vital 100 HEPA Filter Replacement, Filter: 1 단계, 이미지 2/2
    • Unplug the air purifier and remove the cover by pulling the side handle away from machine.
  2. Levoit Vital 100 HEPA Filter Replacement: 2 단계, 이미지 1/1
    • Remove the old air filter by pulling the looped, white tab towards yourself.
    • This comes out without resistance and there are no hooked attachments.
  3. Levoit Vital 100 HEPA Filter Replacement: 3 단계, 이미지 1/1
    • Clean out any remaining dust and hair inside purifier using a vacuum or towel.
  4. Levoit Vital 100 HEPA Filter Replacement: 4 단계, 이미지 1/1
    • Unwrap the new filter and place it inside the air purifier with the tabs at the top and facing outward.
    • The filter should fit in snugly as there are no attachments surrounding the fitting.
  5. Levoit Vital 100 HEPA Filter Replacement: 5 단계, 이미지 1/2 Levoit Vital 100 HEPA Filter Replacement: 5 단계, 이미지 2/2
    • Make sure air purifier cover is fitted properly by sinking the two legs into the holes shown at the arrows in photo one and then replacing the filter cover on the front by simply pushing it forward.
    • The air purifier will not power on unless the filter cover is replaced correctly.
  6. Levoit Vital 100 HEPA Filter Replacement: 6 단계, 이미지 1/1
    • After plugging the air purifier back in, reset the Check Filter Indicator by pressing the filter icon at the top and holding it for 3 seconds.
결론
Enjoy the fresh air!
Cody B
회원 가입일: 03/04/23
133 평판
안내서 1개 작성함
Austin Community College, Team 60-4, Watkins Spring 2023 Austin Community College, Team 60-4, Watkins Spring 2023 회원
AUSTINCC-WATKINS-S23S60G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 107
전체 시간: 1,364
