주요 콘텐츠로 건너뛰기
Lexmark Intuition S505 Ink Cartridges Replacement
  1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: 1 단계, 이미지 1/2 Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: 1 단계, 이미지 2/2
    • Lift the scanning unit, exposing the print head.
  2. Lexmark Intuition S505 Ink Cartridges Replacement: 2 단계, 이미지 1/1
    • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
  3. Lexmark Intuition S505 Ink Cartridges Replacement: 3 단계, 이미지 1/1
    • Lift the frame to expose the ink cartridges.
  4. Lexmark Intuition S505 Ink Cartridges Replacement: 4 단계, 이미지 1/1
    • Push the button located above the designated ink cartridge until it pops out.
  5. Lexmark Intuition S505 Ink Cartridges Replacement: 5 단계, 이미지 1/1
    • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
  6. Lexmark Intuition S505 Ink Cartridges Replacement: 6 단계, 이미지 1/2 Lexmark Intuition S505 Ink Cartridges Replacement: 6 단계, 이미지 2/2
    • Close the scanner unit.
결론
Once your ink cartridges are in place, your printer should now print high-quality documents.
다른 2명이 해당 안내서를 완성하였습니다.
Omar
회원 가입일: 01/23/13
111 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013 회원
CPSU-REGAN-W13S18G38
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 15
전체 시간: 3,253
