주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lexmark Intuition S505 Scanner Unit Replacement
필요한 것
  1. Lexmark Intuition S505 Scanner Unit Replacement, Duplex Unit: 1 단계, 이미지 1개 중 1개
    • Hold the button down with the flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
  2. Lexmark Intuition S505 Scanner Unit Replacement: 2 단계, 이미지 2개 중 1개 Lexmark Intuition S505 Scanner Unit Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the duplex unit from the back of the printer with the duplex unit facing up.
  3. Lexmark Intuition S505 Scanner Unit Replacement, Scanner Unit: 3 단계, 이미지 1개 중 1개
    • Locate the two screw holes that connect the two cylindrical extensions from the top portion of the scanner unit to the printer.
  4. Lexmark Intuition S505 Scanner Unit Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew the two size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
  5. Lexmark Intuition S505 Scanner Unit Replacement: 5 단계, 이미지 1개 중 1개
    • Raise and close the scanner unit to observe that the hinges lock in place when lifted.
  6. Lexmark Intuition S505 Scanner Unit Replacement: 6 단계, 이미지 2개 중 1개 Lexmark Intuition S505 Scanner Unit Replacement: 6 단계, 이미지 2개 중 2개
    • Firmly press the hinges inward toward the middle of the printer on both sides at the same time. The hinges should be easily lifted up and removed.
  7. Lexmark Intuition S505 Scanner Unit Replacement: 7 단계, 이미지 1개 중 1개
    • Locate the three screws connecting the plastic tray to the printer.
  8. Lexmark Intuition S505 Scanner Unit Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the three size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
  9. Lexmark Intuition S505 Scanner Unit Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the plastic cover by unlocking the plastic hinges at the inside edges of the printer. Use a plastic opening tool or a tweezer to slowly move in between the crease around the printer to unlock it.
  10. Lexmark Intuition S505 Scanner Unit Replacement: 10 단계, 이미지 2개 중 1개 Lexmark Intuition S505 Scanner Unit Replacement: 10 단계, 이미지 2개 중 2개
    • Slowly raise, but do not remove the plastic cover with the scanner unit so that it exposes the three cables connecting the scanner unit to the printer.
  11. Lexmark Intuition S505 Scanner Unit Replacement: 11 단계, 이미지 1개 중 1개
    • Carefully unplug the pink cable.
  12. Lexmark Intuition S505 Scanner Unit Replacement: 12 단계, 이미지 1개 중 1개
    • Carefully unplug the gray data cable.
  13. Lexmark Intuition S505 Scanner Unit Replacement: 13 단계, 이미지 1개 중 1개
    • Carefully unplug the white ribbon data cable.
  14. Lexmark Intuition S505 Scanner Unit Replacement: 14 단계, 이미지 1개 중 1개
    • Locate the three ports for the cables from the scanner unit and make sure they are unplugged.
  15. Lexmark Intuition S505 Scanner Unit Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the scanner unit with the plastic cover by lifting it up from the bottom portion of the printer.
    • Be careful with the paper tray and make sure it is evenly lifted through the rectangular hole in the plastic tray
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Raymond
회원 가입일: 01/15/13
48 평판
안내서 2개를 작성함
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013 회원
CPSU-REGAN-W13S18G38
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 1,444
