이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Hold the button down with the flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
Remove the duplex unit from the back of the printer with the duplex unit facing up.
Locate the two screw holes that connect the two cylindrical extensions from the top portion of the scanner unit to the printer.
Unscrew the two size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
Raise and close the scanner unit to observe that the hinges lock in place when lifted.
Firmly press the hinges inward toward the middle of the printer on both sides at the same time. The hinges should be easily lifted up and removed.
Remove the three size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
Remove the plastic cover by unlocking the plastic hinges at the inside edges of the printer. Use a plastic opening tool or a tweezer to slowly move in between the crease around the printer to unlock it.
Slowly raise, but do not remove the plastic cover with the scanner unit so that it exposes the three cables connecting the scanner unit to the printer.
Locate the three ports for the cables from the scanner unit and make sure they are unplugged.
Remove the scanner unit with the plastic cover by lifting it up from the bottom portion of the printer.
다른 2명이 해당 안내서를 완성하였습니다.
