주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Lexmark Z11 수리는 저희 서비스 설명서를 사용하십시오.
  1. Lexmark Z11 Teardown, Lexmark Z11 Teardown: 1 단계, 이미지 1/2 Lexmark Z11 Teardown, Lexmark Z11 Teardown: 1 단계, 이미지 2/2
    • Be sure to remove the power cord and all other connections to and from the device.
    • Remove easily detachable parts.
  2. Lexmark Z11 Teardown: 2 단계, 이미지 1/1
    • To remove the cover and housing use a screw driver to remove the highlighted screws.
  3. Lexmark Z11 Teardown: 3 단계, 이미지 1/1
    • Additionally, remove those two screws at the bottom of the device.
  4. Lexmark Z11 Teardown: 4 단계, 이미지 1/2 Lexmark Z11 Teardown: 4 단계, 이미지 2/2
    • Press the nib marked in green inside and slightly lift the housing from the back plate shown in the first image here.
    • The housing can be removed by lifting and rotating it around the catches on the lower front side of the device highlighted in purple. Finally, it is shifted slightly to the front out of those catches.
  5. Lexmark Z11 Teardown: 5 단계, 이미지 1/3 Lexmark Z11 Teardown: 5 단계, 이미지 2/3 Lexmark Z11 Teardown: 5 단계, 이미지 3/3
    • With this inner part nearly everything is easily accessible. There are two stepper motors:
    • NMB PM42L-048-FEA8
    • 4 wires
    • Mitsumi H9601
    • 5 wires, can probably be resoldered to use 4 or 6 wires
    • There is also an electronics board as well as smaller useful parts like buttons, LEDs, light barriers.
    • Motorola XC901051FTA
    • Motorola 34063 (switching voltage regulator)
  6. Lexmark Z11 Teardown: 6 단계, 이미지 1/3 Lexmark Z11 Teardown: 6 단계, 이미지 2/3 Lexmark Z11 Teardown: 6 단계, 이미지 3/3
    • The motors in detail.
raumschaum
회원 가입일: 02/27/13
371 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 1,420
