주요 콘텐츠로 건너뛰기
Lezyne Micro Drive Battery Replacement
필요한 것
  1. Lezyne Micro Drive Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Mount the light in between a 11mm socket and 22 socket like so in a vice.
  2. Lezyne Micro Drive Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Slowly clamp, the clear light cover will push in. There is quite a lot of resistance.
  3. Lezyne Micro Drive Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Keep on going until the resistance fades. The light cover will be depressed as shown. and the electronics will just fall out.
  4. Lezyne Micro Drive Battery Replacement: 4 단계, 이미지 3개 중 1개 Lezyne Micro Drive Battery Replacement: 4 단계, 이미지 3개 중 2개 Lezyne Micro Drive Battery Replacement: 4 단계, 이미지 3개 중 3개
    • You can see where the electronics slides into.
    • You can see how it is held in with friction from the raised plastic bevel. If you wish to make it easier to disassemble, file the friction bevel down. Don't file down the keying semi circular bevel.
    • The last picture shows the plastic filed down.
결론
To reassemble your device, just put it back together.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
graham
회원 가입일: 08/21/13
350 평판
안내서 1개를 작성함
댓글 30개
Thanks just repaired my Lezyne Macro Drive front light. Light would flicker, just needed to re-solder the top left resistor shown in step 4.
richard taylor - 답글
Thanks to your instruction I was able to fix my lezyne micro drive which had denied to work after short-circuiting the charging leads by accident. Just cut the battery and reconnected it - light was working again! Worked out nicely!
Thanks!
mongo - 답글
Is it a 123 cell it takes? I will do this when I visit my father as he has a large vice. Thanks for the guide!
Aerotec - 답글
Yes a "CR-123" cell 3V lithium ion
graham -
you can just push the electronics and battery out with your thumb. Usually the issue with these batteries is the battery contact gets slightly corroded. Clean it with battery cleaner, and twist the battery a bit for a new and clean connection.
scotdferguson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 30
지난 30일: 83
전체 시간: 35,457
