주요 콘텐츠로 건너뛰기
Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement
필요한 것
  1. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement, Triceps Pushdown Cable: 1 단계, 이미지 1/2 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement, Triceps Pushdown Cable: 1 단계, 이미지 2/2
    • Gym cables can become frayed with overuse, becoming dangerous for the user. So, let’s fix it.
    • Purchase a new cable to replace the old one.
    • I bought my cable from Life Fitness, but other verified gym suppliers carry the cable.
  2. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 2 단계, 이미지 1/1
    • Remove the pulley at the back of the Triceps Pushdown.
  3. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 3 단계, 이미지 1/3 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 3 단계, 이미지 2/3 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 3 단계, 이미지 3/3
    • In order to remove the pulley and the pulley covers from the boom, you’ll need two separate Allen wrenches.
    • You'll use each Allen wrench on either side to remove both pulley covers.
    • Use the left side to stabilize the nut while using the right to take out the screw.
  4. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 4 단계, 이미지 1/2 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 4 단계, 이미지 2/2
    • The left pulley cover will fall off as soon as the screw is out; you'll need to pull the right side off.
    • The pulley will fall out once the screw (and the right pulley cover) are no longer in place.
  5. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 5 단계, 이미지 1/3 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 5 단계, 이미지 2/3 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 5 단계, 이미지 3/3
    • Use an adjustable wrench to remove the lock nut.
    • Rotate the lock nut up with your fingers.
    • Don’t worry about moving the lock nut up entirely.
  6. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 6 단계, 이미지 1/2 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 6 단계, 이미지 2/2
    • Remove the lock nut once you get the cable from the head plate.
    • You will need to use this lock nut again with the new cable.
  7. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 7 단계, 이미지 1/3 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 7 단계, 이미지 2/3 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 7 단계, 이미지 3/3
    • Pull the cable up through the Triceps Pushdown.
    • It will fit through the front pulley without removing the pulley or the pulley covers.
  8. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 8 단계, 이미지 1/2 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 8 단계, 이미지 2/2
    • Slide the new cable through the front pulley.
    • The pulley itself will help as it turns and guides the cable through.
  9. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 9 단계, 이미지 1/2 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 9 단계, 이미지 2/2
    • Guide the cable down the still empty back boom.
    • Separating the end of the cable can help guide the cable back down.
  10. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 10 단계, 이미지 1/1
    • Screw the cable back into the head plate.
    • You don’t need to worry about tightening the lock nut as long as the cable itself is screwed in.
  11. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 11 단계, 이미지 1/1
    • Start putting the back pulley back together.
    • Put the pulley inside the boom.
    • Make sure the cable is on top of the pulley. The cable needs to run through the groove.
  12. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 12 단계, 이미지 1/3 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 12 단계, 이미지 2/3 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 12 단계, 이미지 3/3
    • Place the right pulley first.
    • Align the bites with the built-in groves
    • Push the screw through the pulley to the right side.
    • You'll need to align the pulley cover and the pulley inside the boom in order to push the screw through.
  13. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 13 단계, 이미지 1/1
    • Place the right pulley with the grooves.
  14. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 14 단계, 이미지 1/3 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 14 단계, 이미지 2/3 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 14 단계, 이미지 3/3
    • Use both Allen Wrenches to tighten the screw back into place.
  15. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 15 단계, 이미지 1/2 Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 15 단계, 이미지 2/2
    • Rotate the lock nut down to the bottom of the cable.
    • Use your adjustable wrench to tighten the lock nut until it’s locked into place.
  16. Life Fitness Multi-Jungle MJTP Triceps Pushdown Cable Replacement: 16 단계, 이미지 1/1
    • Use a lightweight to check the cable. Make sure the cable runs along both pulleys.
    • Clip on your favorite Triceps Pushdown attachment, and you're done!
결론
Being able to keep up regular maintenance not only keeps a gym enjoyable but safe.
첨부 문서
Mdreeves
회원 가입일: 09/12/23
253 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 113
