소개
Is your LifePrint 2x3 not holding a charge? The issue at hand may be that the battery is faulty and not working. If your device is failing to hold a charge, the battery may need to be replaced. Consider using this guide to replace the faulty battery in your device.
필요한 것
Orient the LifePrint 2x3 so that the top of the device is facing upwards. Slide the top cover toward the far side of the device and remove it.
댓글 6개
Hi. Where can you buy the replacement battery? Thank you.
Hi can I know where I can buy the battery?
I found it hard to buy the battery, you can buy 2 small Li ion batteries of 3.7V, and put them in series, that way you get a battery you can use
Is something homemade but it works. Reutilize the 5P with the NTC, and connect the NTC to ground if your 3V doesn't have one.
Btw original characteristics are
- 7.4V nominal
- 8.4V charge
- 500mAh
- 3.7Wh
https://es.aliexpress.com/item/100500537...
