주요 콘텐츠로 건너뛰기
LifePrint 2x3 Motor-Feeder Replacement
  1. LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: 1 단계, 이미지 1/3 LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: 1 단계, 이미지 2/3 LifePrint 2x3 Motor-Feeder Replacement, Motor-Feeder: 1 단계, 이미지 3/3
    • Make sure the top of the Lifeprint is facing upwards displaying the Lifeprint logo.
    • Slide open the top cover and remove the top lid.
  2. LifePrint 2x3 Motor-Feeder Replacement: 2 단계, 이미지 1/3 LifePrint 2x3 Motor-Feeder Replacement: 2 단계, 이미지 2/3 LifePrint 2x3 Motor-Feeder Replacement: 2 단계, 이미지 3/3
    • Remove the six screws on the outer sides of the device with the Phillips #00 screwdriver.
    • The motor is highlighted in orange.
  3. LifePrint 2x3 Motor-Feeder Replacement: 3 단계, 이미지 1/2 LifePrint 2x3 Motor-Feeder Replacement: 3 단계, 이미지 2/2
    • After removing the six screws, gently flip the device over so the bottom cover is facing you.
    • Remove the bottom cover by using the opening pick.
  4. LifePrint 2x3 Motor-Feeder Replacement: 4 단계, 이미지 1/3 LifePrint 2x3 Motor-Feeder Replacement: 4 단계, 이미지 2/3 LifePrint 2x3 Motor-Feeder Replacement: 4 단계, 이미지 3/3
    • Remove the four screws using the Phillips #00 screwdriver to access the motor and sensor (highlighted in orange).
  5. LifePrint 2x3 Motor-Feeder Replacement: 5 단계, 이미지 1/3 LifePrint 2x3 Motor-Feeder Replacement: 5 단계, 이미지 2/3 LifePrint 2x3 Motor-Feeder Replacement: 5 단계, 이미지 3/3
    • Remove the component holding the motor and feeder.
    • Using a spudger remove the top piece of the component to get to the motor and feeder.
    • Remove the motor and feeder assembly from the device.
결론
Calli Brown
회원 가입일: 09/24/19
172 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 249
