주요 콘텐츠로 건너뛰기
LifePrint 3x4.5 Battery Replacement
필요한 것
  1. LifePrint 3x4.5 Battery Replacement, Top Cover: 1 단계, 이미지 1/1
    • Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
    • While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
    • Pull the cover with the LP logo up to separate it from the rest of the printer.
  2. LifePrint 3x4.5 Battery Replacement, Inner Cover: 2 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
    • Use an opening tool to remove the inner cover from the printer.
  3. LifePrint 3x4.5 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Remove three 4mm Phillips #0 screws connecting the metal shield covering the battery.
    • Slide out the white power connector with two red wires, two black wires, and one yellow wire from the terminal connected to the circuit board.
    • Apply pressure gently and slowly from underneath the battery from the plastic.
  4. LifePrint 3x4.5 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the printer.
결론
Jacqueline Broderick
회원 가입일: 11/05/19
341 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G2, Barthe Fall 2019 UMass Dartmouth, Team S1-G2, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 3개
Où trouver la batterie ? Quelles caractéristiques ?
Baphi - 답글
C'est parfait mais la batterie EVE P0867 7.4V 900mAh est introuvable... Avez vous un lien ?
Merci
Laurent Villiger - 답글
Thank you for instructions. Do you know where to buy the 7.4V 900mAh battery? I can't seem to find one.....thanks!
Julie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 35
전체 시간: 1,108
