소개
This guide will show you the steps to replace the battery of the LifeTrak C410. Replacement battery can be found here.
필요한 것
Grasp the body of the watch between your thumb and your index finger.
Slide the band through its clasp.
Remove the four 5.24 mm screws using a Phillips #0 screwdriver.
Remove the back panel.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
