주요 콘텐츠로 건너뛰기
Lifetime 4-Foot Adjustable Table Leg Replacement
필요한 것
  1. Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: 1 단계, 이미지 3개 중 1개 Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: 1 단계, 이미지 3개 중 2개 Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: 1 단계, 이미지 3개 중 3개
    • Use the 6 mm Flathead screwdriver to remove the four aluminum slotted screws located on the edges of the table.
    • Use a 5/32" Allen Wrench or 19 mm wrench to remove the two stainless 8-18 steel hex screws from the braces of the table.
  2. Lifetime 4-Foot Adjustable Table Leg Replacement: 2 단계, 이미지 3개 중 1개 Lifetime 4-Foot Adjustable Table Leg Replacement: 2 단계, 이미지 3개 중 2개 Lifetime 4-Foot Adjustable Table Leg Replacement: 2 단계, 이미지 3개 중 3개
    • Clean any glue or adhesive from the braces and hinges before putting it into place.
    • It’s important to clear the screw holes of any material, so that the screws can fit without obstruction.
  3. Lifetime 4-Foot Adjustable Table Leg Replacement: 3 단계, 이미지 3개 중 1개 Lifetime 4-Foot Adjustable Table Leg Replacement: 3 단계, 이미지 3개 중 2개 Lifetime 4-Foot Adjustable Table Leg Replacement: 3 단계, 이미지 3개 중 3개
    • Align the screw holes of the braces with the new leg by inserting it into the frame.
    • While aligning, make sure the new leg fits into the frame slots.
  4. Lifetime 4-Foot Adjustable Table Leg Replacement: 4 단계, 이미지 3개 중 1개 Lifetime 4-Foot Adjustable Table Leg Replacement: 4 단계, 이미지 3개 중 2개 Lifetime 4-Foot Adjustable Table Leg Replacement: 4 단계, 이미지 3개 중 3개
    • Place the two stainless steel hex screws inside of the screw holes located on the leg, and secure each screw with your Allen key or wrench.
  5. Lifetime 4-Foot Adjustable Table Leg Replacement: 5 단계, 이미지 3개 중 1개 Lifetime 4-Foot Adjustable Table Leg Replacement: 5 단계, 이미지 3개 중 2개 Lifetime 4-Foot Adjustable Table Leg Replacement: 5 단계, 이미지 3개 중 3개
    • Screw the four slotted screws back into the frame using a 6 mm flathead screwdriver. Ensure that the entire side where the new leg is being inserted is securely connected to the table once again.
  6. Lifetime 4-Foot Adjustable Table Leg Replacement: 6 단계, 이미지 1개 중 1개
    • Test out the table by unfolding it, and setting it up in a standing position.
    • If the leg is not aligned properly, has loose screws, or missing some screws, make the proper adjustments before using it.
결론
작성자
1다른 기여자 명과 함께
Aphason Aberham
회원 가입일: 09/11/23
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 67
전체 시간: 1,340
