주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming
필요한 것
  1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: 1 단계, 이미지 3개 중 1개 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: 1 단계, 이미지 3개 중 2개 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: 1 단계, 이미지 3개 중 3개
    • Use a spudger to gently pry open the remote case to access the battery compartment.
  2. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 2 단계, 이미지 3개 중 1개 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 2 단계, 이미지 3개 중 2개 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 2 단계, 이미지 3개 중 3개
    • Carefully remove the old battery using a spudger.
  3. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 3 단계, 이미지 2개 중 1개 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 3 단계, 이미지 2개 중 2개
    • Place the new battery into the compartment securely, noting the orientation of its positive and negative sides.
  4. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 4 단계, 이미지 3개 중 1개 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 4 단계, 이미지 3개 중 2개 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 4 단계, 이미지 3개 중 3개
    • Turn the remote upside down and push the cover gently until you hear a click, ensuring it is securely closed.
    • Align the cover to the remote buttons.
  5. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 5 단계, 이미지 2개 중 1개 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 5 단계, 이미지 2개 중 2개
    • Locate the garage door system on top of the garage and open it.
  6. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 6 단계, 이미지 3개 중 1개 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 6 단계, 이미지 3개 중 2개 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 6 단계, 이미지 3개 중 3개
    • Locate the learn button.
    • Press and release the receiver learn button.
    • Within 30 seconds, press and hold remote button.
    • When the opener light flashes, release the remote button which means the programming was successful.
  7. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 7 단계, 이미지 1개 중 1개
    • Press the remote button to ensure it opens and closes the garage door as expected.
    • If the remote does not work, repeat Step 6.
  8. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: 8 단계, 이미지 1개 중 1개
    • In case the remote fails and the garage door is closed, use the side-mounted wall remote for emergency access.
    • Press the green light.
결승점
작성자
1다른 기여자 명과 함께
Luay Ghabayin
회원 가입일: 07/02/24
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 25
지난 30일: 117
전체 시간: 2,040
