주요 콘텐츠로 건너뛰기
Light and Motion SOLA VIDEO2000 battery Replacement
필요한 것
  1. Light and Motion SOLA VIDEO2000  battery Replacement, Unscrew the light head cap: 1 단계, 이미지 2개 중 1개 Light and Motion SOLA VIDEO2000  battery Replacement, Unscrew the light head cap: 1 단계, 이미지 2개 중 2개
    • This step may need some force applied to unscrew the lamp head cap.
  2. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the light head: 2 단계, 이미지 2개 중 1개 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the light head: 2 단계, 이미지 2개 중 2개
    • Gently pull the light head by the PCB, not the plastic cover
    • Take note how the light head connector is guided to the PCB connector, all through the plastic cover guide.
  3. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the cover guide: 3 단계, 이미지 2개 중 1개 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the cover guide: 3 단계, 이미지 2개 중 2개
    • Gently remove the plastic cover guide
    • Take note of the cable management. It will ease the reassembly
  4. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the PCB and battery assembly: 4 단계, 이미지 2개 중 1개 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the PCB and battery assembly: 4 단계, 이미지 2개 중 2개
    • Gently shake the lamp and let the battery and PCB slide in your hand
    • Take note of the location where the PCB will have to slide-in during reassembly
  5. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the O-ring: 5 단계, 이미지 2개 중 1개 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the O-ring: 5 단계, 이미지 2개 중 2개
    • Gently remove the o-ring, clean it and apply o-ring grease
    • Clean the o-ring seats, both on the body and the metallic cap.
  6. Light and Motion SOLA VIDEO2000  battery Replacement, Disconnect the battery: 6 단계, 이미지 2개 중 1개 Light and Motion SOLA VIDEO2000  battery Replacement, Disconnect the battery: 6 단계, 이미지 2개 중 2개
    • Gently disconnect the battery from the PCB
    • Avoid touching the metallic strips (humidity sensor, to detect flooding) If it happens, gently wipe it with a dry, non abrasive, cloth
    • Connect the new battery
결론
Use some force to screw back the lamp head cap, but not too much!
After 3 full discharge cycles, the higher capacity battery will give 65min light at full brightness (vs 45 min with the original battery)
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
ralf
회원 가입일: 06/28/13
363 평판
안내서 2개를 작성함
3가이드 댓글
Bonjour,
Le pack de batteries est cher pour 2 18650.
Y a t il un moyen de faire autrement ?
jpdupin - 답글
C'est pas faux, mais les packs d'accus sont généralement appairés par pièces aux caractéristiques aussi semblables que possible.
Il faut sinon démonter le pack d'origine, et récupérer le PCB... cela demande plus d'outillage et de matériel, et il faudra prendre garde à commander des accus avec languettes à souder (à moins de disposer d'un poste de soudure par points).
Pour qui a le temps et les compétences, ça peut effectivement valoir la peine...
ralf - 답글
Do these batteries also work for the Sola Dive light 800?
Hruijs - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 108
전체 시간: 4,246
