소개
We will be explaining how to replace the arrow button in the Lightahead DV328 camcorder.
There is only one caution that should be noted when working on this device. Opening the cover, which contains the motherboard underneath, should be done with caution. If it is lifted up too much, the piece will snap in half.
필요한 것
Use a spudger to remove the two screw covers.
Remove the two Phillips #0 screws.
거의 끝나갑니다!
결론
