주요 콘텐츠로 건너뛰기
Lightahead DV328 Arrow Button Replacement
필요한 것
  1. Lightahead DV328 Arrow Button Replacement, Arrow Button: 1 단계, 이미지 1/3 Lightahead DV328 Arrow Button Replacement, Arrow Button: 1 단계, 이미지 2/3 Lightahead DV328 Arrow Button Replacement, Arrow Button: 1 단계, 이미지 3/3
    • Use a spudger to remove the two screw covers.
    • Remove the two Phillips #0 screws.
  2. Lightahead DV328 Arrow Button Replacement: 2 단계, 이미지 1/3 Lightahead DV328 Arrow Button Replacement: 2 단계, 이미지 2/3 Lightahead DV328 Arrow Button Replacement: 2 단계, 이미지 3/3
    • Once you are able to lift the cover up, you will then be able to pry off the lens which will allow for the device to open more.
    • Take off the lens cover. Be careful not to pull the device open too much otherwise you will snap it in half since it is made of plastic.
    • Once you have this up, pull up the cover and you will now be able to work on the arrow key button
  3. Lightahead DV328 Arrow Button Replacement: 3 단계, 이미지 1/3 Lightahead DV328 Arrow Button Replacement: 3 단계, 이미지 2/3 Lightahead DV328 Arrow Button Replacement: 3 단계, 이미지 3/3
    • Lay the camcorder on its side. The arrow key button is now in full view.
    • There is a small green piece locking in the arrow key button. Once you remove that, the piece will be able to come out.
    • Gently push on the button and it will come out of the device. Replace as needed
결론
Alexandra McMurray
회원 가입일: 01/20/16
355 평판
안내서 3개 작성하였습니다
USF Tampa, Team 10-2, Remmell Spring 2016 USF Tampa, Team 10-2, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G2
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 193
