주요 콘텐츠로 건너뛰기
Likebook Muses Motherboard Replacement
필요한 것
  1. Likebook Muses Motherboard Replacement, Power off: 1 단계, 이미지 1개 중 1개
    • Power off the tablet by holding down the power button (on the bottom) and tapping "Power off" on screen, then wait 10-15 seconds for the underlying Android system to shut down.
  2. Likebook Muses Motherboard Replacement, Rear Cover: 2 단계, 이미지 1개 중 1개
    • Unscrew the two Torx T2 screws surrounding the USB port.
    • Image needed: showing just the bottom in order to highlight screws in blue
  3. Likebook Muses Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Likebook Muses Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Likebook Muses Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Use the opening tool to pry at the lip in between the bezel and rear cover,
    • then slide in your opening pick with the flat end,
    • and slide it around to undo these clips.
  4. Likebook Muses Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Likebook Muses Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Likebook Muses Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • (Note to self: Try opening the side using opening tools)
    • After releasing the clips, lift the front bezel out.
    • The extension piece for the power button can fall out. Don't lose this!
  5. Likebook Muses Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • The rear cover has been removed.
  6. Likebook Muses Motherboard Replacement, Mainboard: 6 단계, 이미지 3개 중 1개 Likebook Muses Motherboard Replacement, Mainboard: 6 단계, 이미지 3개 중 2개 Likebook Muses Motherboard Replacement, Mainboard: 6 단계, 이미지 3개 중 3개
    • Disconnect the battery.
    • Due to the placement of the battery, the connector may not come out all the way.
  7. Likebook Muses Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Likebook Muses Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Likebook Muses Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Using the pointed end of a spudger, disconnect the touch panel.
  8. Likebook Muses Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Likebook Muses Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Likebook Muses Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the pen input controller.
  9. Likebook Muses Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Likebook Muses Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Likebook Muses Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Lift up part of the tape covering the frontlight connector.
    • Using the flat end of your spudger, disconnect the display.
  10. Likebook Muses Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Likebook Muses Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Peel the tape the rest of the way
    • Using the pointed end of your spudger, disconnect the frontlight.
  11. Likebook Muses Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove these screws using your J00 screwdriver (or a PH00 screwdriver if you don't have one).
    • Remove these screws using your PH00 screwdriver.
    • One of these screws has a tamper detection sticker pasted over the screw head.
    • You should be able to poke the screwdriver through it.
  12. Likebook Muses Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Lift the mainboard out from the top,
    • The speaker connections are only held in with solder, and may break if you're not careful.
  13. Likebook Muses Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Likebook Muses Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Likebook Muses Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • The mainboard has been removed.
결론
작성자
2다른 기여자 명과 함께
Kevin Bhasi
회원 가입일: 12/26/14
1,355 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 10
전체 시간: 162
