주요 콘텐츠로 건너뛰기
Linear Rail V2/V3 Endstop Install
필요한 것
  1. Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: 1 단계, 이미지 3개 중 1개 Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: 1 단계, 이미지 3개 중 2개 Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: 1 단계, 이미지 3개 중 3개
    • M3 Sliding T-Nut
    • Slide in the M3 T-Nut toward the middle of the printer
    • M3X12 BHCS & M3 FLAT WASHERS
    • M3x10 FHCS
    • Adjustable Endstop Mount A
    • Adjustable Endstop Mount B
    • Tighten the M3 screw into the T-Nut
  2. Linear Rail V2/V3 Endstop Install, Endstop install: 2 단계, 이미지 2개 중 1개 Linear Rail V2/V3 Endstop Install, Endstop install: 2 단계, 이미지 2개 중 2개
    • Adjust endstop mount until it is square with the Linear rail
    • Remove stock endstop board form Creality mount and Reuse the stock screws to mount the endstop as shown
  3. Linear Rail V2/V3 Endstop Install, Setting endstop position: 3 단계, 이미지 2개 중 1개 Linear Rail V2/V3 Endstop Install, Setting endstop position: 3 단계, 이미지 2개 중 2개
    • Use M3x12 BHCS to adjust the endstop position, so the nozzle tip is even with the front edge of the bed when the end stop is triggered
    • Check the clearance between the motor and the linear adaptor. When the bed is all the way back against the endstop. There should be a 1-2 mm gap when the endstop is triggered.
결론
작성자
2다른 기여자 명과 함께
AJ Pereira
회원 가입일: 05/29/20
2,735 평판
안내서 16개를 작성함
Tiny Machines 3D Tiny Machines 3D 회원
Community
5 회원들
안내서 41개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 68
전체 시간: 1,847
