주요 콘텐츠로 건너뛰기
Linksys EA6900 Power Port Replacement
필요한 것
  1. Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: 1 단계, 이미지 1/3 Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: 1 단계, 이미지 2/3 Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Linksys EA6900 Power Port Replacement: 2 단계, 이미지 1/1
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Linksys EA6900 Power Port Replacement: 3 단계, 이미지 1/1
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Linksys EA6900 Power Port Replacement: 4 단계, 이미지 1/3 Linksys EA6900 Power Port Replacement: 4 단계, 이미지 2/3 Linksys EA6900 Power Port Replacement: 4 단계, 이미지 3/3
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Linksys EA6900 Power Port Replacement, Power Port: 5 단계, 이미지 1/2 Linksys EA6900 Power Port Replacement, Power Port: 5 단계, 이미지 2/2
    • Locate the power port on both sides of the motherboard.
    • The power port on the top side is in a rectangular black casing.
    • Identify the three prongs where the power port is soldered to on the reverse side.
  6. Linksys EA6900 Power Port Replacement: 6 단계, 이미지 1/3 Linksys EA6900 Power Port Replacement: 6 단계, 이미지 2/3 Linksys EA6900 Power Port Replacement: 6 단계, 이미지 3/3
    • Carefully apply the soldering iron on each of the three points on the bottom side of the motherboard to melt them.
    • Be careful to not touch the motherboard with the soldering iron, you can damage the circuits.
    • After you have melted and removed the solder, flip the mother board around and identify the connecting points of the power port.
    • Use a black spudger to gently separate the power port from the motherboard
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tyler Markiewicz
회원 가입일: 09/15/16
267 평판
안내서 1개 작성함
USF Tampa, Team 11-1, Blackwell Fall 2016 USF Tampa, Team 11-1, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 842
