주요 콘텐츠로 건너뛰기
Linksys EA6900 Router Reset Button Replacement
필요한 것
  1. Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: 1 단계, 이미지 3개 중 1개 Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: 1 단계, 이미지 3개 중 2개 Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Linksys EA6900 Router Reset Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Linksys EA6900 Router Reset Button Replacement: 3 단계, 이미지 1개 중 1개
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Linksys EA6900 Router Reset Button Replacement: 4 단계, 이미지 3개 중 1개 Linksys EA6900 Router Reset Button Replacement: 4 단계, 이미지 3개 중 2개 Linksys EA6900 Router Reset Button Replacement: 4 단계, 이미지 3개 중 3개
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Linksys EA6900 Router Reset Button Replacement, Router Reset Button: 5 단계, 이미지 2개 중 1개 Linksys EA6900 Router Reset Button Replacement, Router Reset Button: 5 단계, 이미지 2개 중 2개
    • Make sure to correctly identify the red router reset button.
    • Locate the four solder points on the other side of the motherboard.
  6. Linksys EA6900 Router Reset Button Replacement: 6 단계, 이미지 2개 중 1개 Linksys EA6900 Router Reset Button Replacement: 6 단계, 이미지 2개 중 2개
    • Be careful when working with the hot soldering iron! Make sure the router motherboard is safely resting on a level and sturdy surface.
    • Carefully apply the soldering iron to the four solders. Avoid touching the motherboard with the soldering iron, this could damage the circuits.
    • Use a spudger to gently pry and remove the reset button once the solder has melted.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Rick Hsu
회원 가입일: 09/15/16
355 평판
안내서 1개를 작성함
USF Tampa, Team 11-1, Blackwell Fall 2016 USF Tampa, Team 11-1, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G1
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 1,745
