소개
USB ports on the router are used to connect and transmit data from another device. Faulty USB ports can be replaced with the proper equipment. This guide will show you how to remove a soldered USB port for replacement.
필요한 것
Locate the USB ports on both sides of the router motherboard. There are six points on the reverse side where the USB ports are soldered onto.
Apply the soldering iron carefully to the six points to melt to solder. Touching the motherboard with the solder can damage the circuits.
After the solder has melted and been removed, gently pry the USB port with a black spudger to separate it from the motherboard.
Confirm that all of the old solder has been removed after the USB port is detached from the motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
