주요 콘텐츠로 건너뛰기
Linksys EA9200 Disassembly
필요한 것
  1. Linksys EA9200 Disassembly, Linksys EA9200 Disassembly: 1 단계, 이미지 1/2 Linksys EA9200 Disassembly, Linksys EA9200 Disassembly: 1 단계, 이미지 2/2
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Linksys EA9200 Disassembly: 2 단계, 이미지 1/2 Linksys EA9200 Disassembly: 2 단계, 이미지 2/2
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Linksys EA9200 Disassembly: 3 단계, 이미지 1/3 Linksys EA9200 Disassembly: 3 단계, 이미지 2/3 Linksys EA9200 Disassembly: 3 단계, 이미지 3/3
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  4. Linksys EA9200 Disassembly: 4 단계, 이미지 1/3 Linksys EA9200 Disassembly: 4 단계, 이미지 2/3 Linksys EA9200 Disassembly: 4 단계, 이미지 3/3
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  5. Linksys EA9200 Disassembly: 5 단계, 이미지 1/3 Linksys EA9200 Disassembly: 5 단계, 이미지 2/3 Linksys EA9200 Disassembly: 5 단계, 이미지 3/3
    • Lift the board and pull down, away from the antennas.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Henry Cates
회원 가입일: 10/01/16
219 평판
안내서 1개 작성함
USF Tampa, Team 9-1, Lacy Fall 2016 USF Tampa, Team 9-1, Lacy Fall 2016 회원
USFT-LACY-F16S9G1
4 회원들
안내서 10개 작성하였습니다
댓글 2개
Thank you for making this guide, Henry! I used this to help disassemble an EA7300. EA7300 has just 4 screws, all under the rubber pads on the bottom. Pull the pads off (they're glued on and pulling them off does not destroy them) and set them aside with the adhesive facing up to keep the adhesive clean for sticking back on. At least for the EA7300, there are no clips in the corners. Pry a front corner enough to slide in any plastic card you don't mind it gets damaged and bent. Push it in as far as possible…you should feel it hit stopping points. Slide the card through the crack to the side towards the stop, which is a clip. … (finishes in next post)
Josiah Freeman - 답글
… (finishing from last comment) If it doesn't pop loose, wiggle the card some or slide back out and in again…should pop the clip open. Once you see a first clip pop open where now the card can slide past it, continue to a next clip. All the clips should pop open in a similar manner. Once one side is popped open, put a toothpick or two into that side to keep it open. The back edge’s clips are different…do the back edge last. Use more toothpicks to keep open sections you open. The back edge pulled out when I wiggled it enough after having the other sides open.
Josiah Freeman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 22
전체 시간: 2,439
