주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Linksys WAG200G 수리는 저희 서비스 설명서를 사용하십시오.
  1. Linksys WAG200G Teardown, open up the router: 1 단계, 이미지 1/2 Linksys WAG200G Teardown, open up the router: 1 단계, 이미지 2/2
    • Turn the router with the bottom facing upwards and locate the 4 feet.
    • Use your nails or the opening tool to pry away each foot to reveal a screw, and unscrew each one.
    • The front of the case can be disconnected from the backside now.
  2. Linksys WAG200G Teardown, remove the antenna: 2 단계, 이미지 1/2 Linksys WAG200G Teardown, remove the antenna: 2 단계, 이미지 2/2
    • The antenna cable is soldered to the board. It can be unsoldered or just cut.
    • Use the pliers to make the underside of the antenna smaller so it can fit through the case hole, and at the same time, pull the antenna itself.
  3. Linksys WAG200G Teardown, remove the board from the case: 3 단계, 이미지 1/1
    • The board can now be removed from the case easily.
    • 10/100 Base-T Dual Port Transformer: HN2064CG
    • CPU: TNETD7200ZDW
    • 10/100 Ethernet Switch : 88E6060-RCJ1
knipwim
회원 가입일: 09/01/18
8,517 평판
안내서 30개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,227
