필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the router with the bottom facing upwards and locate the 4 feet.
Use your nails or the opening tool to pry away each foot to reveal a screw, and unscrew each one.
The front of the case can be disconnected from the backside now.
The antenna cable is soldered to the board. It can be unsoldered or just cut.
Use the pliers to make the underside of the antenna smaller so it can fit through the case hole, and at the same time, pull the antenna itself.
The board can now be removed from the case easily.
10/100 Base-T Dual Port Transformer: HN2064CG
CPU: TNETD7200ZDW
10/100 Ethernet Switch : 88E6060-RCJ1
