주요 콘텐츠로 건너뛰기
Linksys WAP 11 Motherboard Replacement
필요한 것
  1. Linksys WAP 11 Motherboard Replacement, Outer Case: 1 단계, 이미지 1/1
    • Be sure the ethernet and power cables are disconnected from the device.
    • You should also unscrew the external plastic antennas. There is one antenna on each side of the device.
  2. Linksys WAP 11 Motherboard Replacement: 2 단계, 이미지 1/3 Linksys WAP 11 Motherboard Replacement: 2 단계, 이미지 2/3 Linksys WAP 11 Motherboard Replacement: 2 단계, 이미지 3/3
    • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
    • Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot. Once you are hooked behind the boot, pull outwards.
    • This will reveal two small Phillips-head screws. Remove them.
    • Keep these two screws together.
  3. Linksys WAP 11 Motherboard Replacement: 3 단계, 이미지 1/2 Linksys WAP 11 Motherboard Replacement: 3 단계, 이미지 2/2
    • Using two hands (one on the front of the device and the other on the back) apply pressure to the top and bottom seal while pulling the front and back away from each other.
    • This requires significant amount of force.
    • The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
  4. Linksys WAP 11 Motherboard Replacement: 4 단계, 이미지 1/1
    • After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
    • When removing the base, do not damage the wires that are attached to the device.
  5. Linksys WAP 11 Motherboard Replacement: 5 단계, 이미지 1/1
    • This is what the device looks like when it is fully opened.
  6. Linksys WAP 11 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/2 Linksys WAP 11 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/2
    • At this point, you may want to remove the antenna leads as well.
    • Once the antennas have been removed, proceed to remove the remaining three phillips screws fastening the motherboard to the case.
    • Once the screws are removed, your motherboard will separate from the housing.
    • Keep these three screws together and separate from the outer case screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Javier
회원 가입일: 10/12/11
46 평판
안내서 1개 작성함
Cal Poly, Team 3-17, Regan Fall 2011 Cal Poly, Team 3-17, Regan Fall 2011 회원
CPSU-REGAN-F11S3G17
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,598
