소개
Accessing and repairing the internal components of the Linksys WAP 11 requires the device to be opened. This will void your warranty.
필요한 것
Be sure the ethernet and power cables are disconnected from the device.
You should also unscrew the external plastic antennas. There is one antenna on each side of the device.
이 단계에 사용된 도구:Tweezers$4.99
Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot. Once you are hooked behind the boot, pull outwards.
This will reveal two small Phillips-head screws. Remove them.
