주요 콘텐츠로 건너뛰기
Linksys WAP54g Antennas Replacement
  1. Linksys WAP54g Antennas Replacement, Antennas: 1 단계, 이미지 1/2 Linksys WAP54g Antennas Replacement, Antennas: 1 단계, 이미지 2/2
    • Make sure the antennas are in a straight position, not bent, to remove the black casing.
    • Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
  2. Linksys WAP54g Antennas Replacement: 2 단계, 이미지 1/1
    • Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
  3. Linksys WAP54g Antennas Replacement: 3 단계, 이미지 1/1
    • Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
  4. Linksys WAP54g Antennas Replacement: 4 단계, 이미지 1/1
    • Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
  5. Linksys WAP54g Antennas Replacement: 5 단계, 이미지 1/1
    • Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
    • Repeat these steps for other antenna.
결론
After the repairs are made the device should working.
다른 2명이 해당 안내서를 완성하였습니다.
Derek Myers
회원 가입일: 10/04/11
288 평판
안내서 5개 작성하였습니다
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 회원
CPSU-MANESS-F11S21G21
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 2,598
