소개
If the router isn't working and it is established that the antennas are defective this is the guide for you.
Make sure the antennas are in a straight position, not bent, to remove the black casing.
Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
거의 끝나갑니다!
After the repairs are made the device should working.
결론
다른 2명이 해당 안내서를 완성하였습니다.
