주요 콘텐츠로 건너뛰기
Linksys WAP54g Casing Replacement
필요한 것
  1. Linksys WAP54g Casing Replacement, Casing: 1 단계, 이미지 1/1
    • Power down and unplug the device.
  2. Linksys WAP54g Casing Replacement: 2 단계, 이미지 1/1
    • Start by removing the two black rubber stoppers that act as the cushions to the legs of the device. The stoppers are located on the bottom towards the front of the device.
  3. Linksys WAP54g Casing Replacement: 3 단계, 이미지 1/1
    • Once removed two small screws will be visible. With a small screwdriver unscrew the screws.
  4. Linksys WAP54g Casing Replacement: 4 단계, 이미지 1/1
    • Remove the blue front panel from the rest of the device. You can now see the main board.
  5. Linksys WAP54g Casing Replacement: 5 단계, 이미지 1/1
    • Now slide the bottom panel forward and remove it so the main board is attached to the bottom panel.
  6. Linksys WAP54g Casing Replacement: 6 단계, 이미지 1/1
    • From here, remove the wires and nuts connected to the back panel of the casing by pulling the nuts through the holes in the casing.
  7. Linksys WAP54g Casing Replacement: 7 단계, 이미지 1/1
    • Once the bottom panel is removed unscrew the screws from the main board to the bottom panel so the main board is independent of the bottom panel.
  8. Linksys WAP54g Casing Replacement: 8 단계, 이미지 1/1
    • From here, all of the pieces of the casing are removed and the main board is independent of the entire casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Derek Myers
회원 가입일: 10/04/11
288 평판
안내서 5개 작성하였습니다
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 회원
CPSU-MANESS-F11S21G21
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 12
전체 시간: 2,052
