소개
In this guide we will go over removing the top casing.
필요한 것
Remove the antennas from the back of the device. To do this, follow steps 1 and 2 of Installing the Antennas Guide: Linksys WAP54g Antennas Replacement
From here you can take apart the rest of the router apart by following subsequent guides.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Bon Tutoriel. Simple, mais les plastiques sont solidement attacher. Il faut donc forcer pour démonter la partie bleu. Mais c’est possible.
Merci.
