소개
In this guide you will learn where the motherboard attaches to the router and how to separate the two components.
필요한 것
Remove the rubber inserts inside the the two purple feet located on the router's front case.
This may be a challenge, so try the following two methods:
Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
다른 2명이 해당 안내서를 완성하였습니다.
