주요 콘텐츠로 건너뛰기
Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement
필요한 것
  1. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Ball Disassembly: 1 단계, 이미지 1/1
    • Unplug the device to avoid injury.
    • Turn the device over, so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: 2 단계, 이미지 1/3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: 2 단계, 이미지 2/3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: 2 단계, 이미지 3/3
    • Compress the tab by pushing towards the center of the device with a spudger.
    • While compressing the tab, peel the base away from the rotating head.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: 3 단계, 이미지 1/1
    • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: 4 단계, 이미지 1/3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: 4 단계, 이미지 2/3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: 4 단계, 이미지 3/3
    • Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches.
    • Insert a new color panel by pushing it into place while lining up the tabs with the notches.
결론
Nick Kaprielian
회원 가입일: 01/14/14
525 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014 회원
CPSU-FORTE-W14S17G3
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 636
