주요 콘텐츠로 건너뛰기
Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement
필요한 것
  1. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Ball Disassembly: 1 단계, 이미지 1/1
    • Unplug the device to avoid injury.
    • Turn the device over, so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: 2 단계, 이미지 1/3 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: 2 단계, 이미지 2/3 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: 2 단계, 이미지 3/3
    • Compress the tab by pushing towards the center of the device with a spudger.
    • While compressing the tab, peel the base away from the rotating head.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: 3 단계, 이미지 1/1
    • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Light Bulb: 4 단계, 이미지 1/2 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Light Bulb: 4 단계, 이미지 2/2
    • Unscrew the burnt-out light bulb with a counter-clockwise twist.
    • Do not apply too much pressure when unscrewing light bulb, as the light bulb may break.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Nick Kaprielian
회원 가입일: 01/14/14
525 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014 회원
CPSU-FORTE-W14S17G3
5 회원들
안내서 7개 작성하였습니다
댓글 4개
Great! Wasn't sure how to remove the base. Thank you!
derigo1957 - 답글
Saved me a headache. Couldn't figure out how to remove base. Thanks!
mccullough1251 - 답글
Helpful guide. Thank you.
In case there is any confusion, all you have to do is push in that tab on one side and lift. No twisting necessary. Also, the other side will come off.
jgprus - 답글
Thank you so much! I was afraid of breaking the globe. That really helped because I couldn’t figure out how to disconnect the base.
Melissa Fleming - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 15
30일 전: 58
전체 시간: 15,400
