소개
Is your disco ball not sending out groovy beams of light anymore? The most common problem is the light bulb is burnt out. This guide will teach you how to replace that light bulb, so you can get back to partying!
필요한 것
Turn the device over, so that the base is on top.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 4개
Great! Wasn't sure how to remove the base. Thank you!
derigo1957 - 답글
Saved me a headache. Couldn't figure out how to remove base. Thanks!
Thank you so much! I was afraid of breaking the globe. That really helped because I couldn’t figure out how to disconnect the base.
