소개
Has your disco ball stopped rotating and turned into a weird, multi-colored lamp? Use this guide to avoid the party-foul and get that ball spinning!
부품
  1. Turn the device over so that the base is on top.
    • Turn the device over so that the base is on top.
  2. Peel off the piece of metal that is glued to hold the two halves of the base together.
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Unscrew the four 10mm Phillips head screws on the bottom of the device. Once the base is removed, the device should look as shown on the picture.
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
  5. Use a pair of tweezers to crush the sides of the wirenuts. The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Use a pair of tweezers to crush the sides of the wirenuts.
    • The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Pull all of the wires out of the wirenuts.
  6. Separate the wires that belong to the motor. The wires should be small and black.
    • Separate the wires that belong to the motor.
    • The wires should be small and black.
    • Remove the motor.
결론
To reassemble your device, follow these instructions in reverse order, starting from step five.
다른 한 분이 해당 안내서를 완성하였습니다.
Courtney Elliott
회원 가입일: 2014년 01월 14일
354 평판
안내서 3개 작성하였습니다
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014 회원
CPSU-FORTE-W14S17G3
5 회원들
안내서 7개 작성하였습니다
Where can you find a replacement motor?
bellyjb - 답글
I can't find one either!!!!
Dallin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 1,433
