주요 콘텐츠로 건너뛰기
Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement
필요한 것
  1. Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement, Switch: 1 단계, 이미지 1/2 Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement, Switch: 1 단계, 이미지 2/2
    • Unplug the device to avoid injury.
    • Use a Phillips head screwdriver to unscrew the single screw.
    • Hold on to the nut from the other side so you do not lose it.
    • Remove the panel that conceals the switch.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement: 2 단계, 이미지 1/1
    • Hold on to the red disc with needle nosed pliers, and use the Phillips head screwdriver to remove the disc by pushing down.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement: 3 단계, 이미지 1/2 Lite FX Rotating Big Ball of Lite Model 1929 Switch Replacement: 3 단계, 이미지 2/2
    • Remove and replace the white switch.
    • Do not be afraid to pull as this takes a bit of force to remove.
결론
Courtney Elliott
회원 가입일: 01/14/14
375 평판
안내서 3개 작성하였습니다
Cal Poly, Team 17-3, Forte Winter 2014 Cal Poly, Team 17-3, Forte Winter 2014 회원
CPSU-FORTE-W14S17G3
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 689
