소개
The disc drive is typically used in a device to read the information from a CD or DVD using an optical sensor. If the disc tray of your Lite-On LightScribe SHM-165H6S has fallen out of alignment or has broken, you can replace it using this guide. This guide is for the mechanical component of the disc drive, but may also help alleviate disc read errors, or can be used to access the optical sensors for cleaning or maintenance.
부품
지정된 부품이 없습니다.
Insert an open paper clip into the small hole on the left side of the faceplate.
After the tray opens, extend it fully.
Extend the tray fully.
Push the tab on the right side to the left.
Push the tab on the left side to the left.
Remove the tray carefully.
다른 한 분이 해당 안내서를 완성하였습니다.
