주요 콘텐츠로 건너뛰기
Lite-On LightScribe SHM-165H6S Drive Belt Replacement
필요한 것
  1. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Chassis: 1 단계, 이미지 1/2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Chassis: 1 단계, 이미지 2/2
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: 2 단계, 이미지 1/3 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: 2 단계, 이미지 2/3 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: 2 단계, 이미지 3/3
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: 3 단계, 이미지 1/1
    • Pull the faceplate away from the main chassis.
  4. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: 4 단계, 이미지 1/1
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: 5 단계, 이미지 1/2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: 5 단계, 이미지 2/2
    • Lift the top and bottom chassis straight up in order to remove them.
  6. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Drive Belt: 6 단계, 이미지 1/2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Drive Belt: 6 단계, 이미지 2/2
    • Extend the tray so that the belt is accessible.
    • Remove the old belt using tweezers.
  7. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: 7 단계, 이미지 1/2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: 7 단계, 이미지 2/2
    • Carefully replace with the new belt by wrapping it around the larger gear first, followed by the smaller gear.
    No parts? What about the belt? Where do you get these tiny things?
    Scott Whitehill - 답글
    Use a rubber band or an plumbing o-ring
    lilleyen - 답글
결론
다른 5명이 해당 안내서를 완성하였습니다.
James Biggs
회원 가입일: 10/12/11
596 평판
안내서 3개 작성하였습니다
Cal Poly, Team 6-5, Regan Fall 2011 Cal Poly, Team 6-5, Regan Fall 2011 회원
CPSU-REGAN-F11S6G5
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
In case anyone is interested, I used a 11/16” OD x 9/16” I.D. x 1/16” wall, for this exact drive (was a tight fit) and seems to work perfect.
I was so tired of replacing rubber bands every few months!
And yes this is an “O-ring”  it should be less than a buck five eighty at your local big box hardware store.
Jim Mccalb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 6,521
