이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert an open paper clip into the small hole on the left side of the faceplate.
After the tray opens, extend it fully.
Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
Extend the tray so that the belt is accessible.
Remove the old belt using tweezers.
Carefully replace with the new belt by wrapping it around the larger gear first, followed by the smaller gear.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
In case anyone is interested, I used a 11/16” OD x 9/16” I.D. x 1/16” wall, for this exact drive (was a tight fit) and seems to work perfect.
I was so tired of replacing rubber bands every few months!
And yes this is an “O-ring” it should be less than a buck five eighty at your local big box hardware store.
Jim Mccalb - 답글
