주요 콘텐츠로 건너뛰기
Lite-On iHAS324 Disc Tray Belt Replacement
필요한 것
  1. Lite-On iHAS324 Disc Tray Belt Replacement, Chassis: 1 단계, 이미지 2개 중 1개 Lite-On iHAS324 Disc Tray Belt Replacement, Chassis: 1 단계, 이미지 2개 중 2개
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Disc Tray Belt Replacement: 2 단계, 이미지 3개 중 1개 Lite-On iHAS324 Disc Tray Belt Replacement: 2 단계, 이미지 3개 중 2개 Lite-On iHAS324 Disc Tray Belt Replacement: 2 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Disc Tray Belt Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Disc Tray Belt Replacement: 4 단계, 이미지 1개 중 1개
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Disc Tray Belt Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Disc Tray Belt Replacement: 6 단계, 이미지 1개 중 1개
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
  7. Lite-On iHAS324 Disc Tray Belt Replacement, Disc Tray: 7 단계, 이미지 2개 중 1개 Lite-On iHAS324 Disc Tray Belt Replacement, Disc Tray: 7 단계, 이미지 2개 중 2개
    • Push the left tab in and slide the tray out on the left side.
    • Pull the gray plastic casing on the right side away from the tray.
    • Slide the right side of the tray out.
  8. Lite-On iHAS324 Disc Tray Belt Replacement, Disc Tray Belt: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Take tweezers and remove the black tray belt from the gears carefully.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kayla Culpepper
회원 가입일: 03/22/15
702 평판
안내서 5개를 작성함
Baylor, Team 5-9, Williams Spring 2015 Baylor, Team 5-9, Williams Spring 2015 회원
BU-WILLIAMS-S15S5G9
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 25
전체 시간: 1,937
