주요 콘텐츠로 건너뛰기
Lite-On iHAS324 Face Plate Replacement
필요한 것
  1. Lite-On iHAS324 Face Plate Replacement, Chassis: 1 단계, 이미지 1/2 Lite-On iHAS324 Face Plate Replacement, Chassis: 1 단계, 이미지 2/2
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Face Plate Replacement: 2 단계, 이미지 1/3 Lite-On iHAS324 Face Plate Replacement: 2 단계, 이미지 2/3 Lite-On iHAS324 Face Plate Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Face Plate Replacement: 3 단계, 이미지 1/1
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Face Plate Replacement: 4 단계, 이미지 1/1
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Face Plate Replacement: 5 단계, 이미지 1/1
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Face Plate Replacement: 6 단계, 이미지 1/1
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
  7. Lite-On iHAS324 Face Plate Replacement, Disc Tray: 7 단계, 이미지 1/2 Lite-On iHAS324 Face Plate Replacement, Disc Tray: 7 단계, 이미지 2/2
    • Push the left tab in and slide the tray out on the left side.
    • Pull the gray plastic casing on the right side away from the tray.
    • Slide the right side of the tray out.
  8. Lite-On iHAS324 Face Plate Replacement, Face Plate: 8 단계, 이미지 1/1
    • Slide the faceplate off the disc tray.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kayla Culpepper
회원 가입일: 03/22/15
702 평판
안내서 5개 작성하였습니다
Baylor, Team 5-9, Williams Spring 2015 Baylor, Team 5-9, Williams Spring 2015 회원
BU-WILLIAMS-S15S5G9
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 510
