소개
Use this guide to remove and replace the bearings and blade shaft in the Little Wonder 4 HP Honda Pro Edger 62320001 Rev B.
필요한 것
Lift the belt slackener lever to take tensions off the belts.
Secure it in the slackened position.
Use a 3/8 inch socket and ratchet to remove the two bolts securing the belt guard.
Slide the belt guard forward and away from the belt pulley.
Slide the guard to the side, away from the wheels to expose the belts.
Move the blade adjusting lever up into the lowered position to lower the blade.
Use a 3/4 inch socket and ratchet to remove the nut securing the blade.
Brace the left side of the blade against the ground in order to loosen the nut. Brace the right side of the blade against the ground for tightening.
Remove the outer blade washer.
Remove the blade
Remove the inner blade washer.
Use a 9/16 inch socket and ratchet to remove the bolt securing the wheels.
Use a 5/32 hex key to loosen the two set screws securing the belt pulley.
Use a mallet to install the bearing closest to the engine first.
Reinstall the snap ring on the blade shaft.
Tap the blade shaft back into the cutter head, starting from the side closest to the engine.
Reinstall the old key in the new shaft. If your shaft came with a new key, use the old key for this process, then replace it with the new key.
Set the second new bearing in the side of the cutter head farthest from the engine.
Reinstall the blade and both washers.
Use an adjustable wrench to hold the shaft in place. At the same time, use a 3/4 inch socket and a ratchet to tighten the blade nut and push the bearing into the cutter head.
