주요 콘텐츠로 건너뛰기
Little Wonder GX270 Honda Maximum Output Blower Fan Replacement
필요한 것
  1. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement, Safety precautions: 1 단계, 이미지 1/2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement, Safety precautions: 1 단계, 이미지 2/2
    • Before you begin, ensure that the engine is off and cool to the touch.
  2. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 2 단계, 이미지 1/2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 2 단계, 이미지 2/2
    • Locate the gas cutoff valve and flip the switch to the left to shut it.
  3. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 3 단계, 이미지 1/2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 3 단계, 이미지 2/2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement, Remove the intake guard: 4 단계, 이미지 1/1
    • Use a 1/2 inch wrench to remove the intake guard bolt behind the front wheel.
  5. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 5 단계, 이미지 1/2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 5 단계, 이미지 2/2
    • Use a 1/2 inch socket to remove the five bolts securing the intake guard.
  6. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 6 단계, 이미지 1/2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 6 단계, 이미지 2/2
    • Remove the intake guard.
  7. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement, Remove the fan blade: 7 단계, 이미지 1/2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement, Remove the fan blade: 7 단계, 이미지 2/2
    • Use an impact wrench to remove the 5/8 inch bolt securing the fan blade to the spindle.
  8. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 8 단계, 이미지 1/2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 8 단계, 이미지 2/2
    • Remove the fan plug bolt and fan plug.
  9. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 9 단계, 이미지 1/2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 9 단계, 이미지 2/2
    • Remove the fan blade.
  10. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 10 단계, 이미지 1/2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 10 단계, 이미지 2/2
    • Use a pair of pliers to remove the key from the spindle.
  11. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 11 단계, 이미지 1/2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: 11 단계, 이미지 2/2
    • Remove the fan spacer.
    • Wipe the old grease off the spindle with a shop towel and apply new grease before installing the replacement parts.
결론
Sam Omiotek
회원 가입일: 02/25/19
73,369 평판
안내서 288개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 657
