주요 콘텐츠로 건너뛰기
Logic Board Disconnection
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Logic Board Disconnection, Disconnect the logic board: 1 단계, 이미지 1/2 Logic Board Disconnection, Disconnect the logic board: 1 단계, 이미지 2/2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
    • Depending on the condition of your bits, a T4 Torx driver may fit better.
    • Remove the trackpad connector bracket.
  2. Logic Board Disconnection: 2 단계, 이미지 1/2 Logic Board Disconnection: 2 단계, 이미지 2/2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  3. Logic Board Disconnection: 3 단계, 이미지 1/3 Logic Board Disconnection: 3 단계, 이미지 2/3 Logic Board Disconnection: 3 단계, 이미지 3/3
    • If the left speaker is already disconnected, skip this step.
    • Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  4. Logic Board Disconnection: 4 단계, 이미지 1/2 Logic Board Disconnection: 4 단계, 이미지 2/2
    • Use a T3 Torx driver to remove the two 1.3 mm screws securing the USB-C port connector bracket.
    • Remove the USB-C connector bracket.
  5. Logic Board Disconnection: 5 단계, 이미지 1/2 Logic Board Disconnection: 5 단계, 이미지 2/2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  6. Logic Board Disconnection: 6 단계, 이미지 1/3 Logic Board Disconnection: 6 단계, 이미지 2/3 Logic Board Disconnection: 6 단계, 이미지 3/3
    • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
    • Slide the sound board cable out of the ZIF connector.
  7. Logic Board Disconnection: 7 단계, 이미지 1/1
    • Peel back the black tape covering the fan cable connector.
  8. Logic Board Disconnection: 8 단계, 이미지 1/3 Logic Board Disconnection: 8 단계, 이미지 2/3 Logic Board Disconnection: 8 단계, 이미지 3/3
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  9. Logic Board Disconnection: 9 단계, 이미지 1/2 Logic Board Disconnection: 9 단계, 이미지 2/2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  10. Logic Board Disconnection: 10 단계, 이미지 1/3 Logic Board Disconnection: 10 단계, 이미지 2/3 Logic Board Disconnection: 10 단계, 이미지 3/3
    • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  11. Logic Board Disconnection: 11 단계, 이미지 1/2 Logic Board Disconnection: 11 단계, 이미지 2/2
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  12. Logic Board Disconnection: 12 단계, 이미지 1/2 Logic Board Disconnection: 12 단계, 이미지 2/2
    • Use the flat end of a spudger to pry up the display cable connector.
결론
Adam O'Camb
회원 가입일: 04/11/15
196,299 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 116
