주요 콘텐츠로 건너뛰기
Logitech Circle Speaker Replacement
필요한 것
  1. Logitech Circle Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Logitech Circle Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Wedge the plastic opening tool under the black circle lens to gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Speaker Replacement: 3 단계, 이미지 1/2 Logitech Circle Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Speaker Replacement: 4 단계, 이미지 1/2 Logitech Circle Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Speaker Replacement: 5 단계, 이미지 1/2 Logitech Circle Speaker Replacement: 5 단계, 이미지 2/2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Speaker Replacement: 6 단계, 이미지 1/2 Logitech Circle Speaker Replacement: 6 단계, 이미지 2/2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Speaker Replacement: 7 단계, 이미지 1/1
    • Locate the speaker attachment, and carefully remove the speaker plug from the lens.
  8. Logitech Circle Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the speaker using a plastic opening tool. The battery is attached with glue, so use gentle prying motions to remove speaker.
결론
Emma Cochran
회원 가입일: 09/28/17
110 평판
안내서 1개 작성함
University of Maine, Team S1-G4, Diaz Fall 2017 University of Maine, Team S1-G4, Diaz Fall 2017 회원
UMAINE-DIAZ-F17S1G4
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 23
전체 시간: 368
